Sponsored by: Auxito
no 12 volt
Old Jan 22, 2004 | 09:03 AM
zedosix's Avatar
zedosix
no 12 volt
I have a new trailer with interior lights, and am not able to use them. Should I not have a 12 volt source from the truck to the 7 plug harness? I turned the ignition on and tested the plug terminals one at a time. I thought it was the centre plug. Any ideas. Its a 2003 f350 diesel, if you need to know.
Old Jan 22, 2004 | 09:09 AM
luckild's Avatar
luckild
Center usually for accessories. May not have fuse under the hood, in the distribution box. Check it out and let us know. Good luck.
Old Jan 22, 2004 | 11:24 AM
zedosix's Avatar
zedosix
Everything is in order. Thanks for your comments. There was power to the plug. The only think I can think of is that I washed the trailer yesterday and it was 15 below celcius, so maybe the connection was wet or something.
