1978 - 1996 Big Bronco
Sagging Door
Old Jan 21, 2004 | 09:41 PM
BGL's Avatar
BGL
Sagging Door
The driver side door of my 94 EB has got a slight sag in it. A lot of times when I go to shut the door I have to really push on it to fully close it. Any ideas on what might be causing this and how to fix it?
Old Jan 21, 2004 | 10:01 PM
ANdrewdrice's Avatar
ANdrewdrice
check the bolts to affix the door, they might be loose.
Old Jan 21, 2004 | 10:58 PM
BOJOFASO's Avatar
BOJOFASO
open the door all the way and lift it up and down, is there any play? if so investigate the hingesand repair as nessacery. if there is no play check your body mounts. if you want you can place a screwdriver handle between the door and jam near the lower hinge and gently push the door as if you were going to close it and it will bend the hinge mount up and the door will probably shut correctly.
