bad fuel pump?
Old Jan 21, 2004 | 04:27 PM
lilpig88's Avatar
lilpig88
bad fuel pump?
i haven't driven my truck a lot lately, but i have noticed that the oil always seems to smell like a little gas is in it. i changed the oil and a little while later (couple hundred miles) there is the gassy smell again. the motor only has about 1500 miles on it, but the fuel pump was not replaced at the time of rebuild. could a bad fuel pump cause gas to get in my oil? are there any other ways that this could happen besides really bad blowby?
thanks
Old Jan 21, 2004 | 05:19 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Is the oil level going UP?
It just could be running rich, or not enough to burn it off. Sounds like it hasn't been run much. That makes it smell worse too...
Old Jan 21, 2004 | 05:21 PM
Putt's Avatar
Putt
Two ways for gas to get into your oil, I think. One- bad fuel pump diaphragm leaking into oil. Two- carb running EXTREMELY rich(won't hardly run when it's that rich).
I'd replace your fuel pump.
Putt
Old Jan 21, 2004 | 07:15 PM
lilpig88's Avatar
lilpig88
thanks for the quick replies. the motor runs great. i had to mess with the carb after the rebuild (engine and carb) for a while to get it to run this well, so i don't think it's running too rich. i suppose i'll go for a new fuel pump and go from there.
thanks
jrohr
Mar 7, 2015 01:43 PM
yewdall
15
Sep 4, 2013 10:14 PM
justforkicks
Oct 21, 2009 09:26 PM
First_Ford
Jan 18, 2005 07:30 AM
Racer1
Sep 16, 2003 07:00 AM
