Aerostar Ford Aerostar
unplugged wire
Old Jan 21, 2004 | 11:09 AM
tarpen's Avatar
tarpen
unplugged wire
i have an unpluggeed wire near the thermostat ,, cant find a plug,,any sugestions?
Old Jan 21, 2004 | 11:34 AM
copper_90680's Avatar
copper_90680
On my 3.0L 93 Aerostar, there is another plug identical to that one, and that plug goes into the coolant temperature sensor near the thermostat housing. The plug you mentioned is not connected anywhere. I guess Ford uses the same wiring harness for different cars or different versions of the Aerostar, hence the two identical plugs. On another car, that plug would be used for a coolant temperature sensor located lower than the one on the Aerostar. Hope this helps you sleep better at night :-)
Regards,
