Sponsored by: Real Truck
60 mph vibration
Old Jan 21, 2004 | 07:28 AM
mjs's Avatar
mjs
60 mph vibration
For the past couple of months, I have been battling a very annoying vibration in my truck. It exists from 45mph to about 75mph, but is most prevailent at 60mph. This vibration is noticeable when I am holding a constant speed and seems to be coming from the rear of the truck. If I accelerate slightly, it seems to disappear. The problem started back in November, right about when it started to get cold. It has been to the dealer 3 times and scheduled to go back next week. On the 1st trip, they balanced the tires. No differnence. On the 2nd trip, they said two of the tires are severely out of round, so they put on 4 new tires. No difference. On the 3rd trip, they said my two rear wheels were bad, so they replaced those. Still no difference. They have also checked the driveshaft balance, U joints, hanger bearing, etc and all is good.
The truck is an 03 F350 CC, V10, 3.73 and completely in stock form right now. 11,000 miles on it.
Does anyone have any ideas? I told them to keep the truck next week until it is fixed, but I am not very confident they will find anything.
MJS
Old Jan 21, 2004 | 08:00 AM
FortyFords's Avatar
FortyFords
These can be a pita to find!
I'll list some things for them to chk
some you have already chk
1)tires
2)u-joints( make them replace)
3)center carier bearing (shim it down sligthly)
4)runout on rear diff flange(dial indicator)
5)internal carrier bearings in rear dif
6)runout on rear rotors
7)rear axle bent
8)driveshaft balance
9)rotate tires to the front
10)torque converter in trans(if auto)
11)flywheel /6speed 12 )flexplate /auto
Just a few !
Don't give up ,stay on it
they'll find it
Rich
Old Jan 21, 2004 | 11:19 AM
ADL's Avatar
ADL
I have mine in the shop now it had a vibration from 40mph and up but only under acceleration or going up hill none when decelleration / down hill. It was the rear U Joint .
02 cc psd 6 spd.
Old Feb 2, 2004 | 08:47 AM
mjs's Avatar
mjs
I noticed something with my vibration issue this weekend. I loaded my wife's snowmobile in the box and the vibration got much worse.
has anyone else had a issue with a CC SWB truck vibrating with ANY amount of weight in the box?
MJS
Old Feb 2, 2004 | 05:47 PM
fitter565's Avatar
fitter565
Have you had your driveshaft out of the truck???If you did, did you put it back exactly like it came out? If there not put back the same as they came out, it could cause a vibration.(They are balanced from the factory as a unit). If thats not the case check to see if the shaft has thrown a balance weight. Just a couple of things to check, hope this helps.
Fitter
wogdiml
Nov 19, 2010 03:52 PM
jnye6625
2004 - 2008 F150
Feb 14, 2010 04:02 PM
mjs
Jun 21, 2005 09:46 AM
mjs
2004 - 2008 F150
19
Feb 19, 2005 12:31 PM
mjs
Nov 5, 2002 10:14 AM
