Highboy springs = steering problems?
Old Jan 20, 2004 | 08:47 PM
Screamin T/A's Avatar
Screamin T/A
I plan on getting a set of pre 1977 f250 front leaf springs to put under my 79 f250 and then do the rear shackle flip to gain about 2-3" of lift to clear a set of larger tires. I was wondering if I would run into any steering problems when I put the front springs on? Would I need a drop pitman arm? Draglink? Any other suggestions? I have a 3" body lift now and 35's? I want to fit 38's maybe. What do you all think?
Old Jan 20, 2004 | 09:00 PM
leadmic's Avatar
leadmic
You might need to raise the steering arm at the knuckle with a spacer.
Leadmic
Old Jan 20, 2004 | 09:21 PM
plowpusher's Avatar
plowpusher
they make a lift kit for your truck why not use it?
Old Jan 20, 2004 | 09:41 PM
Screamin T/A
I wanted to do the lift for as cheap as possible because money is a little tight. So do I definetly need to put the steering block in?
Old Jan 21, 2004 | 09:49 AM
skuteman's Avatar
skuteman
You may create alot more problems than you bargained for if you start altering your suspension and Don't fully understand all the ramification(s) of the changes that you want to make!!!!!s.kuteman
Old Jan 21, 2004 | 10:54 AM
Screamin T/A
I dont understand what you mean skute? I hear a lot of people do the shackle flip, and I have heard that the highboy springs work fine. What problems would I be running into?
Old Jan 21, 2004 | 11:01 AM
73highboy4x4's Avatar
73highboy4x4
i don't think highboy springs will fit on a 79'. i think they are longer and or wider, and will not fit
Old Jan 21, 2004 | 12:33 PM
ranger429's Avatar
ranger429
Screamin T/A you might here flippin the shackles on a JEEP but I have never heard of flipping the shackles on an F-series from our vintage. I just went out and looked at my truck and I think it would be next to impossible to do without removing and making new spring perch hangars.best bet is to wait and save your dough for the correct lift
Old Jan 21, 2004 | 03:17 PM
leadmic's Avatar
leadmic
Highboy springs will fit a 79 and a shackle flip will work great. Thease guys (http://www.sky-manufacturing.com/) make rear brackets to make a shackle flip easy or you can use the front bracket off a 73-79 two or forwheel drive lief spring an install it in the back. Its not that hard. You might have to use a spacer to get your steering arm back to the right place.
Leadmic
Old Jan 21, 2004 | 03:34 PM
ranger429's Avatar
ranger429
learning every day LOL nice site leadmic
