calling corey872
Gabe
It's been so dang cold I haven't really messed with it anymore. Someone posted about a bulletin which said that the rear bearings can wear out and the ring can loose it's clearance tolerance with the sensor. Upon a second look at the old sensor I took out:
I see one place where the body is dented (lower left arrow) and another place where it is scuffed (upper right arrow). I know that with my truck, the speed signal comes from this sensor alone. Are you talking about a front wheel ABS sensor? I don't think the speedo readout actually comes from those, but maybe if you had a bad one it could affect the rest of the system?
Let me know how it turns out!
