steering colunm
Old Jan 19, 2004 | 07:53 PM
mpenni's Avatar
mpenni
steering colunm
any tricks to removing this steering colunm.?
Old Jan 19, 2004 | 08:55 PM
jj292's Avatar
jj292
What steering column? We would all like to help but a little more info on you specific application and what you are trying to acomplish is needed.
Thanx, JJ
Old Jan 19, 2004 | 09:03 PM
ghostflamed66's Avatar
ghostflamed66
What year truck. Most of them you remove holding bolt from steering coupler. Remove bolts at firewall holding column and seal.
Remove shift link.
Unbolt from dash
Unhook turn signal wires.
Column should then pull out
Hope this helps.
Old Jan 19, 2004 | 09:36 PM
mpenni's Avatar
mpenni
okay it's a 64 F-100 straight shaft to the gear box. 4-speed granny so no linkage. but it won't lift a 1/4'' off the gear box?
Old Jan 19, 2004 | 09:42 PM
ghostflamed66
Dumb question. Did you pull bolt out of rubber steering coupler. It is a splined shaft with a knotch. So bolt needs to be pulled out,if i remember right.
Old Jan 20, 2004 | 08:26 AM
jj292's Avatar
jj292
Remember no "Dumb Questions". The only dumb question is the one not asked. That is the only way any of us learned this stuff was to ask dumb questions.
Any way aslong as you unbolted all the connectors and brackets the column should slip out. Unless something is warped, twisted, mushroomed...etc. then you have a problem (trust me lots of swearing, truck hit a GOOD size rock and it bent everything. Not a slick but it still applies).
JJ
Old Jan 20, 2004 | 05:23 PM
truckfarmer's Avatar
truckfarmer
61-64 have the columns attached to the gear box. You have to remove both as they are one piece.
Old Jan 20, 2004 | 07:10 PM
jj292's Avatar
jj292
there must be two different types. The steering column on my 63 sebarated at the box, it wen on to a splined shaft and held on with a compression bolt.
JJ
Old Jan 20, 2004 | 08:07 PM
BobbyFord's Avatar
BobbyFord
I've got a 62 and a 63 and the steering shaft that the steering wheel bolts to is part of the gear box. The column slides over the shaft. Column comes off while the shaft stays with the box.
