big-block conversion
Old Jan 19, 2004 | 07:41 PM
ShortTemper's Avatar
ShortTemper
I'm trying to swap a dual-carbed 460 for the stock inline-6 that's in my 86 F-250. Any tips, tricks, or trouble hints would be greatly appreciated. I have 3 big blocks and no where to put so i figured i would stuff one in the truck and then use the 300 I-6 for an airboat project.
Old Jan 19, 2004 | 07:46 PM
Roger Carter's Avatar
Roger Carter
Try L and L Performance. They offer complete conversion kits. Not the least expensive, but they are complete. I have found them to be very high quality and to work.
Good luck.
Roger Carter
Old Jan 19, 2004 | 08:36 PM
Franklin2's Avatar
Franklin2
That body style had 460's originally form the factory. So some stuff from the junkyard should make the swap possible.
Of course you know the bellhousing for the six is different than the big block.
Old Jan 20, 2004 | 05:57 PM
Bandito1961's Avatar
Bandito1961
I think the mounts that the motor mounts bolt to are the same but the trans from the 6 will not match up to the 460. You need to double check that to be sure any way just some things to look at
Old Jan 20, 2004 | 09:27 PM
Franklin2's Avatar
Franklin2
Nope. I forgot about that till you mentioned it. He will have to grind the rivets off the frame perches and get some v8 frame perches. And I believe the 460's had some different type of mounts with the rubber mounts too. The junkyard would have them.
Old Jan 21, 2004 | 12:47 AM
Superdave's Avatar
Superdave
They have to be 460 specific perches to use the factory mounting set up.
Old Jan 21, 2004 | 09:09 AM
66MercMan's Avatar
66MercMan
I used the tranny mount from my I6 to mount a 76 460 with c6 in my 1980 F-100. but I built motor mounts out of both the factory I6 and 460 mounts to where they needed to be. But if you can find a truck with 460 it should have the motor mounts you need. I had looked at L& L but it was just too expensive.
Old Jan 21, 2004 | 10:10 PM
serving_time's Avatar
serving_time
Are the mounting perches 460 specific or would they work from a 351M or a 400? I am asking because I am considering putting a 460 into an F150.
Old Jan 22, 2004 | 12:26 AM
Superdave's Avatar
Superdave
No, the 351M 400 perches will not work if you use the factory 460 engine mounts.
What year of truck might you be working on?
