Sponsored by: Auxito
interior light
Old Jan 19, 2004 | 08:30 AM
christaylor's Avatar
christaylor
interior light
98 F150 interior light will stay on after I start the engine until about 15 mph. anyone else having this problem? and the light on the dash will stay on for the door adjar
Thanks
Chris
Old Jan 19, 2004 | 08:57 AM
MJEmerson's Avatar
MJEmerson
try spraying some WD40 or other lube on the door latches. Also there is a rubber accordian type hose that goes from the truck to the door. you can see it with the door open. your switch is inside there. move that hose around and make sure it is properly positioned. its some kind of pressure switch I think, so if it gets out of allignment it does not switch. any way I had a similar issue on my 97. but start with the WD40 first...hope this helps.
cbrown9064
16
Dec 30, 2013 10:49 PM
danlee
Electrical Systems/Wiring
Jan 7, 2010 06:23 PM
chris491
Aug 3, 2007 09:14 AM
