4.6L Swap - Missing Something???
Old Jan 19, 2004 | 07:08 AM
yellow53's Avatar
yellow53
Angry 4.6L Swap - Missing Something???
I am installing a 4.6L in my 53 F-100. I cannot get it to start. I can spray gas direct into the intake and the motor will run for a second or two but the injectors never release gas into the intake. I have the complete wiring harness, solenoids, and fuel system from the donor vehicle. I have good pressure on the fuel rail. I have only one hard code 565 - canister purge valve circuit open. I have beaten my head black and blue trying to figure out what is happening. Does anyone have a clue?? What makes the PCM fire the fuel injectors?
HELP!!!
Yellow53
Old Jan 20, 2004 | 06:15 AM
LxMan1's Avatar
LxMan1
Welcome to the forum. What is the donor vehicle?
Old Jan 20, 2004 | 06:22 AM
yellow53's Avatar
yellow53
1994 - P71 - Crown Vic. I have installed the complete drive train.
yellow53
Old Jan 23, 2004 | 09:08 PM
jokey's Avatar
jokey
check and see if you dont have that ford sen key security. I did a swap like this with a freind it was the dohc from a mark 8 and we ran into the same problem
