Sponsored by: Real Truck
FOGLIGHT SWITCH MODIFICATIONS
Old Jul 16, 2002 | 12:00 PM
DAVE1092's Avatar
DAVE1092
Does anyone know of a modification to the headlight switch to get the foglights to come on with the running lights? I have a 2002 F250 SD PSD. Thanks.
Old Jul 16, 2002 | 12:14 PM
UNIMOG's Avatar
UNIMOG
If you have the 'auto-light' option on your truck, you can turn the light switch to that postion (auto-light, to the left, aka: counter-clockwise), and pull out to have the fog-lights on, only. No running lights or regular headlights in that postion. They function as day-light running lights since they will go on and off with your igniton switch, in that postion.
Mark Peterson
'02 CC, SB, V10
Old Jul 16, 2002 | 06:17 PM
Distinctive Dave's Avatar
Distinctive Dave
The only other thing you can do is run a jumper wire from power to the fog light wire behind the switch so they are on all the time. I ran a jumper from my parking light wire to the fog light wire so i can have my parking lights and fogs on at the same time.
2001 F-350 CC Lariat 4X4 LB PSD SRW, Heated leather, off road package, western snow plow, strobe lights in parking lights and backup lights, tinted windows, pioneer cd player, rockford fosgate 1000x1 amp rocking 3 JL Audio 10W0's behind back seat, husky liners front and back, Hypermax "hot rod" chip, Hypermax pryo/boost gauge and Hypermax 3.5 inch downpipe and 5 inch exhaust.
Old Jul 16, 2002 | 06:22 PM
redranger1's Avatar
redranger1
and if you do not have the option talked about in the above response take a peak at this thread
https://www.ford-trucks.com/dcforum/superduty/2425.html
should have all the info ya need.
-nathan
Old Jul 17, 2002 | 09:59 PM
DAVE1092's Avatar
DAVE1092
Thanks for all the help. I will have to read through all the info and give it a try on mine. I will let you all know what I find out. My switch does not pull out with the parking lights. They must have used whatever switch they had laying around. I tried to do this on my 98 F150 a couple of years ago with no luck. All I did was blow fuses. I found the relay that controlled the foglights and noticed that the polarity on the switching circut of relay would reverse when I switched the lights on. Anyways I'll try to do this in the next week or two if I can get a break from the yard work.
Old Jul 17, 2002 | 10:46 PM
superv10's Avatar
superv10
