F.E motor mounts
I noticed the other day that the engine seemed to move around more then it should .
What I found was a bent stud on the mount (driverside)
I loosened the nut up and put two big flat washers on the stud and tightened everything up again .
THe engine has only been in the truck for 2 mounths and already the new mounts are failing .
I was wondering if anyone knows of a good mount that is made in the USA that will not pull apart?
I am hard on motor mounts I pulled the mount apart on my 1989's 300 I6 .
other then that my 360 is running great with no problems -other then fuel mileage .
