Rattling noise
Old Jan 18, 2004 | 08:47 PM
79redranger's Avatar
79redranger
Rattling noise
I have a 2000 Explorer XLT. At idle it make a rattling noise that almost sounds like a grinding noise. Could that just be the lifters or could it be something more?
Old Jan 19, 2004 | 08:24 PM
78fordman's Avatar
78fordman
Lifters are more of a ticking type of sound, rattling noise i would open up the hood, and basicly take a look, turn on the a/c and see if it goes away. If it was anything internal i would either be loud knocking, or ticking. Does it vibrate, or more or just a sound? Does it do it in gear? What are you using for an oil filter, if it is a fram take it off and go to motor parts and get a hastings or a wix, a lot better filter. Also might want to try changing the oil, make sure to use 5w-30, and put a quart of marvels mystery oil in it. Rattling is kinda vague, is it from the engine compartment, or more towards the transmission? Could be a loose converter bolt, i had a friend with a camaro which had a simular problem, but its what i expect from a chebbie. Is there excessive blow by if you disconnect to PCV valve? Is the transmission fluid level normal?
Old Jan 19, 2004 | 09:27 PM
79redranger
When it's in gear it vibrates and rattles. Once it chugged when in reverse, but it hasn't done that for about a month now. Both Rangers and the Explorer have had an oil cange in the last month with motocraft filters. ATF is good and no lights come on. Could just be a case of the shakes, but it's been doing this for some time.
Old Jan 20, 2004 | 09:23 AM
78fordman's Avatar
78fordman
Change the fuel filter, run injector cleaner through it, it sounds like it is being starved of fuel at low speeds, get a new fuel filter. Also how long has it been doing this? Just in the cold monthes? If so run a obttle of heat through it, maybe a little ice in it.
