Sponsored by: Real Truck
Transmission temp
Old Jul 15, 2002 | 08:54 PM
slammer's Avatar
slammer
Transmission temp
I installed a trans temp gauge and took the 28' fver to a softball tournament this past weekend. It was about 85 degrees ( thats damn hot for northern minnesota) and the trans guage read about 165 degrees. Does that sound okay?. I dont have a baseline to go by but without the f'ver hooked up it reads about 110.
Thanks guys...........
Old Jul 16, 2002 | 12:15 AM
V10man's Avatar
V10man
Transmission temp
Sounds perfectly normal. I hit 165 in stop and go traffic unloaded. Towing in the summer heat only goes to about 175. As long as you're under 225 or so you're ok.
Old Jul 19, 2002 | 10:23 PM
darth's Avatar
darth
Transmission temp
I run between 125 and 150 (max so far) unloaded. Haven't put the 28' Terry behind it yet.
Old Jul 20, 2002 | 07:15 PM
sportscar's Avatar
sportscar
Transmission temp
Anybody have details on installing a temp gage?
Old Jul 20, 2002 | 11:35 PM
darth's Avatar
darth
Transmission temp
[updated:LAST EDITED ON 21-Jul-02 AT 00:39 AM (EST)]Yep,
I am assuming you want it for a ford , there other truck installs over there. I bought the kit from the diesel guys and it plugs right in just as Dick's article describes. The only improvement I would add is where to get the 12V run source, I have a post here on the best way to get it, and posted an update on the diesel website but it won't be published for a while, so look here.
dennis
Old Jul 21, 2002 | 05:42 PM
wolfmanagh's Avatar
wolfmanagh
Transmission temp
