Y pipe
Old Jan 18, 2004 | 04:44 PM
jklimko's Avatar
jklimko
Y pipe
any idea where i can pick up a new y pipe along with a heat riser for 351 w 86 f 150 super cab
Old Jan 18, 2004 | 06:57 PM
NascarMark06's Avatar
NascarMark06
If It's got a converter in it, you'll probably have to go to the dealer. Although, some part stores sell direct fit converters already built into the y-pipe. A cheaper alternative might be to dual out the exhaust sustem. plus it makes more power and sounds great.
Old Jan 18, 2004 | 07:09 PM
jklimko's Avatar
jklimko
The duals would be the answer --- already equipted with duals without cat -- for pa inspection the mech must do a visual and the cats must be on --- since the y pipe has been hacked i need to go the stock set up
Old Jan 18, 2004 | 08:53 PM
bremen242's Avatar
bremen242
Walker part number 15793. Has both front & rear cats with air tap in the middle. $222.48
look on www.partamerica.com. They have, and they are the suppliers for advance auto, kragen and a few other. If you live in PA, there is probably an Advance Auto around the corner.
Btw, are the mech doing a visual on the A.I.R. pump as well, or just the CATs? just curious as i'll have to get mine done soon.
Old Jan 19, 2004 | 08:38 AM
jklimko's Avatar
jklimko
They now look at all parts of emission system -- air pump - canisters and they have to check the emission tags to decide what your veh has to have -- alos the note tire size
I guess if you have changed engines you may have a real problem or had to replace the rad core or fenders and lost tags, I guess you have to find the tags somewhere
I am in fayette co, so we are a little diff from westmoreland
Old Jan 19, 2004 | 07:08 PM
bremen242's Avatar
bremen242
Are they checking everything in fayette too? or just if you have cats?
Old Jan 19, 2004 | 09:08 PM
jklimko's Avatar
jklimko
we don't do the state emission testing just the visuals - they even record the tire size don't knoow why but they do.
