Sponsored by: Auxito
Missing Oil
Old Jan 18, 2004 | 02:32 PM
chapman's Avatar
chapman
Missing Oil
I have 1999 F150 w/ a 5.4L with 85,000 miles on it and it seems to use oil. It does not leak or burn any of it. Any solutiuons
Old Jan 18, 2004 | 04:14 PM
MJEmerson's Avatar
MJEmerson
its gotta be going somewhere. Check the oil, for antifreeze, gas, etc. You can taste the antifreeze, and the gas you can smell, and the oil will be thinned out. The leak could be internal, which should be looked at right away. are there any performance issues?
Old Jan 18, 2004 | 05:44 PM
Racerguy's Avatar
Racerguy
Hi chapman and welcome to FTE
How much oil does it use?
Old Jan 18, 2004 | 05:55 PM
chapman's Avatar
chapman
None of that is going on. Maybe a little loss in performance but I use work and seems to be normal wear and tear on the performance thing. Could the PCV valve be plugged. I heard that somewhere before.
