4x4????
Old Jan 18, 2004 | 01:15 PM
golfboy17's Avatar
golfboy17
4x4????
I cleaned the shift motor on my 92 explorer in nov, the 4x4 worked great after that, but sometimes i would have to push the button several times to get it to go into 4x4, i read in another post about a bumper or something that brakes, i was wonderiing were that was and how i would do that?? And today i went to put it into 4x4 i herd one click then 3 sec later another click right now am restarting the computer disconnected neg. battery cable for 15min thats what am waiting for now, looks like i will have to attempt cleaning it again i also want to try and replace the rubber bumper as well if someone can tell me how to do that and if any one knows any other possible causes, i was just usiing it thursday in the snow now today it wont work please help
Old Jan 18, 2004 | 03:36 PM
Opera House Works's Avatar
Opera House Works
Never heard that one. I run the motor in for about 30 minutes before installing. You have to remove the encoder gear so it doesn't run into the stop. I have found that many motors are still too stiff. Run the motor off 12V with a brake light in series. If it wo't rin then go back to step one. Motor should easily run at about 3/4 amp. Have seen some motors still drawing over 4A because bearings are still dry.
Old Jan 18, 2004 | 04:59 PM
golfboy17's Avatar
golfboy17
just took it apart and the bushing and the surface they ride on were black again, just cleaned it in nov and it was clean
Old Jan 18, 2004 | 05:00 PM
golfboy17's Avatar
golfboy17
oh and after i cleaned it i put it all back together and it would not go back in some how the thing turned or something had to re due it about 3 times then finally i put one of the long screws in the motor tightend it to the t-case and put the second bolt in and now all is fine works great
