Unknown rear axle...help!
Old Jan 18, 2004 | 12:24 PM
Stark's Avatar
Stark
Hey guys, I recently bought my '74 F100 (2WD) and the previous owner told me that "a buddy of his" put in a bigger rear axle than the stock one. So I was wondering if I could get some help figuring out what axle it is.
The only numbers I could see on it were on the front (toward front of truck) side: D2SW-C ,and lower down: 2649. Its a 10-bolt cover that opens from the front also, so there's no rear cover.
Lemme know if I need to search for other numbers or anything else to help figure this out. Thanks
Old Jan 18, 2004 | 12:48 PM
archangel's Avatar
archangel
If the bolts are on the front, it sounds like the stock 9 inch rear that came in it!
The third member (the removable housing with the gears in it) might be modified though.
Old Jan 18, 2004 | 04:42 PM
hoxiii's Avatar
hoxiii
The truck might have originally had a D44, then the 9" would be an upgrade.
Justin
Old Jan 19, 2004 | 02:00 AM
archangel's Avatar
archangel
A 1974 F100 would have had a 9 inch in it.
Old Jan 19, 2004 | 11:19 AM
hoxiii's Avatar
hoxiii
I thought the D44 was an option clear into the 70's.
Justin
Old Jan 20, 2004 | 03:11 AM
archangel's Avatar
archangel
"I thought the D44 was an option clear into the 70's."
On the front, for sure.
But I dont think so for the rear.
Old Jan 20, 2004 | 06:50 AM
Boss_358's Avatar
Boss_358
Some F-100's did have rear Dana 44's. I have only seen one that I can remember well.
Old Jan 20, 2004 | 01:10 PM
Txquadhunter24's Avatar
Txquadhunter24
the upgrade was probably from a 28 spline 9" to a 31 spline 9". the read you stated is a 9" since it has the removable 3rd member like already stated. if i had to bet on it, i'd bet it was upgraded from 28 to 31 spline rear.
dooger54
All Things Towing
33
Jul 26, 2016 12:56 AM
abosely
Mar 27, 2016 05:37 PM
FastGilla
Apr 21, 2011 09:25 AM
grizzlyadams73
Aug 14, 2003 09:42 PM
