FM-145 Trans
Old Jan 18, 2004 | 11:53 AM
Lucky Charms's Avatar
Lucky Charms
Unhappy FM-145 Trans
I have put a new clutch pak along with throw out bearing & slave cylinder into this trans. I cannot get the trans in gear when the truck is running. If I turn the truck off & put in gear then try to start it the truck lunges foward. WHAT COULD BE THE PROBLEM!!!:
Old Jan 18, 2004 | 11:59 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hello-
Welcome to Ford Truck Enthusiasts! The Internet's leading Ford TRUCK and SUV Resource!
This thread has been moved from Garage and Workshop Tips forum where we share ideas about how to organize tools, heat the shop, or free that rusty bolt.
Unfortunately no truck tech questions are allowed there. Please scan down the list of available forums and place your topic in the most specific forum you can find, -fairly simple to do and just takes a moment.
Please take the time to read the headings and notices in each forum. The FTE board is HUGE! We want users to be able to find answers to their questions so it is organized into many areas and search tools are provided.
If you have any questions please feel free to contact a moderator.
Please (show) turn on your email function. Users do not have access to your actual email address.
Thanks for using FTE!
-Eric, Torque1st, FTE Forum Manager
73-79 Trucks, Garage and Workshop Forum
Old Jan 18, 2004 | 12:09 PM
4starcstms's Avatar
4starcstms
I went thru this with.. uhm another brand truck.. about a year ago. Just keep pumping the pedal. It took three diff people to get mine to have good pressure, or about a 30-45 min of pumping. Worked great till it was totaled last month.
Pump Pump Pump! Look at it this way, maybe you can skip a trip to the gym!
Old Jan 19, 2004 | 06:42 PM
Lucky Charms
Talking Thanx 4star/fm-145 trans
THANX 4STAR,
I took your advice . I let the truck sit over night
& when I got home from work I tried it. I started it then began a five min pumping session It did'nt go in @ first but then the sun shined again. It works like NEW!!!
Thank You
Lucky Charms
P.S
After sitting for a month
the alternator is SHOT
