M50D problem
Old Jan 17, 2004 | 05:56 PM
smittylite's Avatar
smittylite
M50D problem
Having a major issue with my 97 Explorer's manual tranny. It will not go into gear unless the engine is shut off. I noticed an audible click noise when depressing the clutch pedal and the pedal seems unnecessarily soft. This has happened "overnight" as the last time I drove it it the clutch pedal was giving good resistance, for lack of a better term. Could someone here give me a couple suggestions of what might be the problem? Thanks in advance.
Also, the clutch and master slave cylinder were replaced roughly 2 years ago at the dealership.
Old Jan 23, 2004 | 05:00 PM
opporll's Avatar
opporll
im guessing your slave cylinder is shot.....again
Old Jan 25, 2004 | 01:54 AM
Talyn's Avatar
Talyn
I personally would say its common for these to go out.
try bleeding the lines first if you know how. Otherwise, take it to dealership and have them try bleeding the lines to see if that fixes the problem.
Old Jan 25, 2004 | 09:29 AM
shotgun's Avatar
shotgun
shotgun
Try just removing the cap and strainer on the clutch fluid reservoir. Ensure fluid is full. Then try to pump up the peddle. See if you can get pressure that way. I talked with a guy that said he had to do that every once in a while. I think he had a vent problem in his cap and it would kinda "vapor lock".
Old Jan 26, 2004 | 01:36 PM
smittylite's Avatar
smittylite
thanks for the info.
