Aerostar Ford Aerostar
power windows
Old Jan 17, 2004 | 04:18 PM
areoroot's Avatar
areoroot
power windows
both power windows in my 93 areostar wont work, The fuse is good and I have power to the switch. Is there an inline fuse somewhere that I am missing?
Old Jan 17, 2004 | 11:40 PM
rlmdad's Avatar
rlmdad
areoroot,
If you have power to the switch, then either your switch is bad, wiring from the switch to the motor is bad, or the power window motors may have a problem. Check for power going to the motor when the switch is activated. These are two wire DC motors that operate by switching the power lead depending on whether you're opening or closing the window.
To my knowledge there are no inline fuses or relays between the switch and the motor.
Ron
