'94 explorer remote program
Old Jan 17, 2004 | 10:15 AM
genoflh's Avatar
genoflh
Hi,
I have a '94 Explorer ltd and am trying to get the remote lock keyfob to work, it came from another Explorer. I put new batteries in, and tried the suggested cycle the ignition 4 or more times, but no luck. Are the locks supposed to click after cycling the key?
Old Jan 17, 2004 | 12:00 PM
96explorereddieb's Avatar
96explorereddieb
Yes, your door locks will lock then unlock after cycling the ignition from off position to on position without starting your engine 5 times. It may not work because you don't have the system installed from the factory or your RKE module is broken.
Old Jan 17, 2004 | 05:06 PM
genoflh's Avatar
genoflh
If it is installed, where would I find the module that controls the remote lock option, and how would I test it?
