Newb here
Old Jan 16, 2004 | 06:45 PM
Sport98's Avatar
Sport98
Newb here
Please help...A/c dies(stops blowin) while excelerating and at highway speeds if the peddle is being laid into(not much but you know to pick up a bit more speed...
I have a 98 sport with 90k.....
TIA
Kamell
Old Jan 17, 2004 | 01:17 AM
c96drumm's Avatar
c96drumm
See if it's blowing out of the defrost vents when that happens. If so, your vacuum accumulator or the vacuum line going to it is leaking. The accumulator supplies vacuum during periods of low engine vacuum such as when you're accelerating. The accumulator is a black plastic ball under the hood with a vacuum line going to it. There is a check valve involved in there somewhere that could be bad and cause that problem.
Old Jan 17, 2004 | 03:27 AM
jclj2003's Avatar
jclj2003
that might be a normal thing because when you are idleing that compressor is turning makeing the freon gas at a lower pressure but when you speed up the compressor turns faster makeing the freon less presure and causeing the low presure switch to kill out shuting the compresor off or you could be low on freon causeing this too because my car had te same problem but brought it to a ac place and they said that was normal what i had said you may not understand but if you put a specail pressure gauge on that ac system you will see what i mean
low rpm= high presure on low side
high rpm=low presure on low side = ac compressor shuting off by kill switch
Old Jan 17, 2004 | 03:40 AM
c96drumm's Avatar
c96drumm
Sport98 said it stops blowing, not that the air changes temperature. Sounds like you're describing a different symptom, there, jclj2003.
Old Jan 17, 2004 | 03:43 AM
jclj2003's Avatar
jclj2003
oh ok i thought he was talking about the cold stops blowing and gets warm well that will help if anyone has that problem
Old Jan 21, 2004 | 12:59 AM
Sport98's Avatar
Sport98
Thanks for all the imput,Maybe i should have been a little more clear.The Ac blows pretty cold i have to say,specialy in this 115deg az weather.The problem im having is,while excelerating from any point or any speed the ac stops blowing!The system is still on but no fan action?It also will make this distinct howling type whisling sound wile at a light pr just parked while running.This usally happen after running for a while.Tia fellas
