Sponsored by: Auxito
97' A/c
Old Jan 16, 2004 | 06:26 PM
Rollbar's Avatar
Rollbar
97' A/c
Has anyone had a problem w/their a/c .
It doesn't blow hardly @ all on high & I took the fan out & everything is fine.
@ one time I had to use the heat to get it to blow hard & then it would revert back to blowing @ a very low volume.
Just wondered if you all ran into this problem.
Thanks,
Old Jan 17, 2004 | 06:15 PM
Racerguy's Avatar
Racerguy
Is it the same in all positions? Does it have low volume out all the vents, defrost, floor etc?
Old Jan 17, 2004 | 06:41 PM
Rollbar's Avatar
Rollbar
All positions yes. It sounded like it was blowing hard but it's not.
like it's not @ full throttle etc.
Like I said I took out the fan & checked the squirrel cage & no restrictions.
I was thinking the the condenser was clogged?????????????
Thanks,
RollBar
Old Jan 17, 2004 | 07:11 PM
Rollbar's Avatar
Rollbar
What do ya think?
Old Jan 17, 2004 | 07:15 PM
Racerguy's Avatar
Racerguy
Just being nitpicky here but the condenser is the piece in front of the radiator. The piece you're talking about is the evaporator
That could be plugged or possibly the air intake which is under the wiper cowl on the passenger's side of the truck.
If your truck has a pollen filter installed it could also be plugged. Take a look at https://www.ford-trucks.com/forums/s...B%25252Bfilter for a picture of it.
Old Jan 17, 2004 | 08:07 PM
Rollbar's Avatar
Rollbar
Originally posted by Racerguy
[B]Just being nitpicky here but the condenser is the piece in front of the radiator. The piece you're talking about is the evaporator
DUHHHHH, I got it mixed up,
Thanks, I'll check it out.
RollBar
Old Jan 17, 2004 | 08:19 PM
Rollbar's Avatar
Rollbar
Nope, don't have a cabin filter. That stinks.
Thanks allot for the tip,
RollBar
Old Jan 19, 2004 | 09:01 AM
MJEmerson's Avatar
MJEmerson
I think there is a flap that opens and closes somewhere under the dash. I wonder if that could be stuck...or your switch is bad. just my two cents
Old Jan 19, 2004 | 10:06 AM
Rollbar's Avatar
Rollbar
I'll check it,
thanks
