mricorp
The plug is behind the tow hook on the drivers side,
Crawl under and look around ,It is zip tied from the factory
all nice and neat.
Good luck!
Yep,
as someone said before, too many 2002 owners were finding them so Ford tried a better hiding place !
try looking up from the bottom between the bumper/towhook and the radiator - use a flashlight !
and zip tied to the BLACK wire loom running down the side of the radiator will be a BLACK three prong plug with BLACK tape around it and a BLACK plastic plug....
mine was on the passenger side...
remember if you cut it loose how much wind is in there when driving - if left loose will beat up your radiator...
Many have done ingenious mods to mount in on front bumper/behind front license plate holder, etc...
do a search for heater plug and you'll see some neat stuff !
