Aerostar Ford Aerostar
aerostar awd front hub assembly
Old Jan 14, 2004 | 08:46 PM
sarkis's Avatar
sarkis
Talking aerostar awd front hub assembly
Hi All,
is there a reference online to see if the Aerostar hub assembly
is interchangeable with other ford models?
tia
sarkis
Old Jan 15, 2004 | 12:02 PM
aerocolorado's Avatar
aerocolorado
Not aware of any online sources. Hollander Interchange manuals are usually available at your local library or you might try asking at the local scrapyard.
Old Jan 15, 2004 | 10:05 PM
rebocardo's Avatar
rebocardo
I have owned or worked on many Fords, I think the AWD hub fits only the Aerostar. You can find the hub listing in a TRW catalog, along with torque specs, if you want to flip hrough the pages and try to match the part number to something else.
Old Jan 18, 2004 | 08:28 PM
txzaphod's Avatar
txzaphod
Thumbs up
I just replaced the front hub on my 92 AWD just a couple of months ago. I recommend that
I had originally gagged at the $260+ price from the dealer, but found an aftermarket at one of the local discount parts places (from a manufacturer with a know name) for $130.
I pulled the truck into my driveway at 9:15 one morning, and
pulled back out of the driveway with a new hub installed at 10:45.
The most unstraightforward pard of the job was separating the old hub from the spindle. I tapped a thin putty knife in at the joint to loosen it. It was suprisingly easy.
Just make sure that you have a new nut for the end of the axle shaft. I believe it requires a 30mm socket to remove the axle nut, and a 12pt-12mm(if I remember correctly) to remove the 3 bolts attaching the hub to the spindle.
Good Luck
Steve
Austin, TX
92 4.0 XLT Extended AWD
96 Volvo 850 Turbo Wagon
83 BMW 320i
72 Datsun 240Z
