Is this the norm?
Old Jan 14, 2004 | 06:02 PM
AGE mechanic's Avatar
AGE mechanic
Question Is this the norm?
When cranking the motor up, It takes a second or two to fire off. My 01 Cummin's used to fire up as soon as you bumped the starter. The motor build is a 6/03 and I dont know which flash I have. Does this cranking issue sound like the norm or not?
Old Jan 14, 2004 | 07:29 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
see this
https://www.ford-trucks.com/forums/s...hreadid=192549
STROKER_350's Avatar
STROKER_350
Same for me, No worries
Old Jan 14, 2004 | 07:50 PM
psdwanabe's Avatar
psdwanabe
The injectors wont fire until the brain knows where the pistons are, this takes 1 revolution. After that the injectors start firing, and .......Houston.........we have lift off!
Old Jan 14, 2004 | 08:28 PM
AGE mechanic
Thanks for the info
Old Jan 14, 2004 | 10:17 PM
4x4Mark's Avatar
4x4Mark
Just a curiousity, but might this also be due to the method used to actuate the injectors? Maybe needs a bit of oil pressure first, and thus a couple of revolutions?
Just a shot at a thought
Old Jan 15, 2004 | 07:41 AM
emtabmm's Avatar
emtabmm
Just for the record, Ford says up to 11 sec.'s of crank time for gassers and diesels to lite...
Old Jan 15, 2004 | 08:03 AM
IB Tim's Avatar
IB Tim
The 11 seconds is not long, I wonder why it comes up?
Old Jan 15, 2004 | 08:26 AM
emtabmm's Avatar
emtabmm
Because most owners think that an engine should start immediatley....
Old Jan 15, 2004 | 08:29 AM
IB Tim's Avatar
IB Tim
Well...this forum is to educate and discuss
We can do that!
