Bronco II Ford Bronco II
replacing power door lock motor
Old Jan 14, 2004 | 04:25 PM
CrazyFazy's Avatar
CrazyFazy
My ford manual only refers to the door lock itself not the electric one that locks all doors. I cant really see inside what to disconnect but I suspect it is just a clip. After drilling out the pop rivet that holds this to the door what do I replace the rivet with? Can I just use a small bolt and nut? I have a pop rivet gun but no pop rivets. Can I measure diameter of the hole and possibly purchase the correct size? Trying to fix some of the little problems I have left go over the years before there are too many. LOL. Thank you.
Old Jan 14, 2004 | 05:02 PM
lgamech's Avatar
lgamech
aluminum pop rivets are available in most home stores. I would take a drill bit the same diameter of the hole and use that as a gauge for the rivet size.. hope it helps
Old Jan 14, 2004 | 05:36 PM
peck1987's Avatar
peck1987
if you have a bad door lock actuator, you can pick one up cheap at partsexpress.com. you will have to do a little extra work because these are a universal actuator, but they are around 10.00 each.
Old Jan 15, 2004 | 08:23 PM
PJF's Avatar
PJF
If you can't find the right size pop-rivet, use a 10-32 by 1/2inch (I believe that's the size I used) nut and bolt to replace it. Grab a few extras just incase you have to change the power window gear/motor - that's if you have that option.
