Sponsored by: Real Truck
Power Steering Woes
Old Jan 14, 2004 | 03:13 PM
case2273's Avatar
case2273
Power Steering Woes
1999 f350 PSD 4x4 is experience power steering problems. 25% of the time it appears I have rack and pinion. The pump is constantly "whirring" when the truck runs but when I turn the wheel lock to lock it busts up my forearms. Any help would be appreciated. Fluid level is fine. Cooler on front of truck feels hot.
Old Jan 14, 2004 | 04:15 PM
99f350sd's Avatar
99f350sd
jack the front up and disconnect the damper. With steering wheel unlocked you should be able to grab a tire and turn it with little force...if not you may have axle,balljoint, ujoint problems.
