question for any one
Old Jan 13, 2004 | 09:33 PM
48 fat ford's Avatar
48 fat ford
in the glove box of my truck i found the original keys and a small round tag about the size of a quarter with a hole drilled in it it is stamped FK297
RECORD
DETACH
H
IM NOT SURE THAT IT GOES WITH THE TRUCK I ASUMED IT DID BECAUSE IT WAS WITH THE KEYS IF ANY ONE CAN TELL ME WHAT IT IS OR IF IT GOES WITH MY TRUCK IT WOULD HELP THANK YOU
Old Jan 14, 2004 | 12:26 AM
mtflat's Avatar
mtflat
Sounds like a key code disk. The first one I remember seeing was the one that came with a new 72 Plymouth Duster.
Dealer kept track of the codes and if you needed replacement keys or were locked out, they could supply a new key.
Old Jan 14, 2004 | 06:53 AM
barry's Avatar
barry
Yes, it's the key code disc. It may go to your truck. The problem is to find a locksmith that can cut the code for you. If you can, have it done and see if the key fits. If it works, you're golden!
Barry
50 F-1
