engine swap
Old Jan 13, 2004 | 06:55 PM
bscott00's Avatar
bscott00
engine swap
I have an 85 F150,302.... came with FI now has a 4bbl carb. It's a 4 sp. manual w/a granny gear. I was gonna sell the truck but have decided to keep it and rebuild it.This will be my first full on rebuild. Is there a 351 that will bolt to my tranny or should I do the 302. I'd like to upsize the motor if I'm gonna rebuild but don't want to have to swap out the tranny.
Old Jan 13, 2004 | 07:35 PM
andym's Avatar
andym
The 351 and the 302 share the same bellhousing pattern. She'll bolt up fine.
Old Jan 13, 2004 | 07:43 PM
ecarter50's Avatar
ecarter50
351w will bolt in using same mounts, bellhousing, radiator, etc. The exhaust may require modifications. Power steering pump and A/C compressor brackets are the same except for one piece. 302 flywheel will bolt on 351w but it is balanced differently. You will need a 28oz flywheel from a 351w or 81-earlier 302. 82-later 302 have 50oz imbalance.
