need advice fast help please
Old Jan 13, 2004 | 06:30 PM
swampo's Avatar
swampo
Ok I just bought a 66 f150 with 390 gears and a 352 would this be too steep of a setup to drive 1200 miles on the interstate would that make the engine crank to much help me out guys!!
Old Jan 13, 2004 | 07:14 PM
cobraguy's Avatar
cobraguy
If you stay to the slower lane you should be OK just be patient and you'll get there.
Old Jan 13, 2004 | 07:35 PM
TremecGT's Avatar
TremecGT
Should be fine! Make sure there is brake fluid and the tires/brakes are safe!
Old Jan 13, 2004 | 09:29 PM
JB 66 F260's Avatar
JB 66 F260
My truck has a 390 with 456 gears and had 31 inch tires, it was no fun to drive home but just kept it slow and I got there.......you shoud too!!!
Old Jan 14, 2004 | 05:40 AM
ddavidv's Avatar
ddavidv
I'll be the dissenting vote and say it will be cranking some RPMs on the highway, which will not help your mileage any.
Getting a lower ratio rear shouldn't be hard. Most V8 F100's came with a 2.73 to 3.08 or thereabouts ratio. Certainly easy enough to swap around. Cruising speed in mine thus equipped is 65-70 mph and gets 12-15 mpg.
Old Jan 14, 2004 | 05:46 AM
jowilker's Avatar
jowilker
Neil, It'll handle 60-65 no problem, thing it you might want to talk to your personal banker before you start out . I suspect about about $200.00 just in gas for the trip. The old F350 duallys used to run those rpms so you'll not have any problems.
I never heard of 390 gears though. The 352 sd mostly had 3.25 and the 352 autos 3.00.
Hope you have a safe trip.
John
Old Jan 14, 2004 | 06:25 AM
ol yeller's Avatar
ol yeller
Maybe tow it on a dolly. Mine had that and a 200 mile trip usually meant 2 fillups. A friend and I changed out the rear for one out of a six cyl. Doesn't pull as well but mileage has improved.
