Cab swap
Old Jan 13, 2004 | 11:30 AM
Scoarch's Avatar
Scoarch
Cab swap
Hi all.
just got my baby in the shop last night.
will be tearing out engine and tranny to reseal them, they work well but leak.i am also going to swap my cab from my doner truck to my project truck. now i have never done this before and do not know were i should start. should i try to take front clip off in one piece? then engine and tranny? then cab?
any words of wisdome from pepole who have done this would be appreciated
thanks to all that reply
https://www.ford-trucks.com/user_gal...?&albumid=7406
Old Jan 13, 2004 | 02:25 PM
KJKozak2's Avatar
KJKozak2
You could try to take the clip off in one piece, but I don't think it'll be easy.
I took mine off to make a tilting clip and documented the disassembly process bolt by bolt. If you're interested, I can send you the Word doc on it.
I didn't take the cab off, but I did put a body lift on it. I ended up disconnecting everything as if to do a cab swap, but never actually moved it off the frame.
The whole precess isn't bad. The bolts that hold the radiator support on and the ones that hold the cab to the frame are the toughest part of the whole job.
It'a aslo a good idea to MARK EVERYTHING you take apart so you know how it goes back together. It seems like a lot of work, but I can tell you from experience, it's well worth the time.
Kevin K.
Old Jan 13, 2004 | 05:39 PM
r2525t's Avatar
r2525t
Keep In mind that you need the title off the doner truck so that you can 'legaly' drive it.
Good Luck!
Old Jan 13, 2004 | 06:51 PM
Scoarch's Avatar
Scoarch
yea, i have the tittle for both trucks. both are regesterd to me now.
Old Jan 13, 2004 | 07:03 PM
ranger429's Avatar
ranger429
why do you need the title from the donor truck?? the vin # is on a plate on the driver door. now if you are using the donor's door's you might want the title, or just swap out your vin plate from your old door
Old Jan 13, 2004 | 07:47 PM
73highboy4x4's Avatar
73highboy4x4
taking the front clip of is not that hard, just unhook the hoses and wiring, you can leave the hood on or take it off, i would take it off if you are lifting it with manpower, two guys should be strong enough, take the bolts off the fire wall, there are rubber tabs on the insde of the fender on the firewall, a bolt on the bottom of each fender by the door, and bolts between the door hinges that are "tricky" to get to, i used a ratcheting box end to get them off with the door half opened, or take the door off since you are changing cabs, as far as the cab i unbolt the cab mounts and the steering, the bolts may be rusted in and you may need a torch, angle grinder or sawzall to get them off, if you dont have a tractor or cherry picker or something the cab is heavy so you will need alot of help with it. i have switched a couple of bodies and it is not that hard i did it in a weekend, dont be surprised if the holes in the frame where the cab mounts to are rusted out, i welded in some big washers to fix this
Old Jan 14, 2004 | 09:19 AM
KJKozak2's Avatar
KJKozak2
Scoarch,
I can't e-mail you due to server problems on my end, so I'm posting here.
Follow this link to the disassembly instructions.
As for the tilting front clip, I don't have any written details or drawings. There is, however, a lengthy post in this forum titled "Possible to make a tilting front end". I have a link in there to 30-some pictures I took a few weeks ago showing most of the detail.
There's also tons of great ideas from others that have, or are in the process of making one.
Hope this helps.
Kevin K.
Old Jan 14, 2004 | 10:16 AM
73Custom's Avatar
73Custom
It sure would be easier to lift out the motor/trans with the front clip and cab off...
Marty
Old Jan 14, 2004 | 12:50 PM
hillbillyk's Avatar
hillbillyk
what if you take the bed off, and put the cab on from the back, seems alot easier then removing the engine and tranney if you don't want them out anyway. I am planning on doing a cab swap on my 78 4x4, gonna pull the bed and do it from the rear.
Old Jan 14, 2004 | 02:19 PM
73Custom's Avatar
73Custom
Re: Cab swap
Hillbillyk, you must've missed the begining of his first post.
Marty
Old Jan 14, 2004 | 03:00 PM
hillbillyk's Avatar
hillbillyk
yeah, I missed that part, thanks for clearing me up. how do ya'll think it would work from the back though. Taking the front clip apart is real easy, I've done it a few times. and most of the bolts are the same, makes it real easy.
Old Jan 14, 2004 | 08:26 PM
Scoarch's Avatar
Scoarch
I want to thank you all for your input. it was a great help in steering me the right way.
kjkozak2 i would really like to thank you for the dissasembly doc. i am sure it would be a big help.
will be starting the cab swap tonight . have 2 weeks to do it . this is going to be fun
cya all
