MAJOR ANNOUNCEMENT Predator For 6.0L
#31
SB- By the way- you're 100% correct in that if Garrett gives their limits in TOT, we should be using that- they have done the calculations to turn it back into component temp. I guess that's when I will get a new downtube with a welded temp sensor boss- anyone seen one out there? Looks like a pain to pull that tube off the back of the engine!
#32
Tekrep, I agree. Whatever Garrett uses is what we should follow. I hope everyone understands that TOT is going to limit them on hot days and once they fry those turbine blades, it is a matter of time before it fails. This is important to us who live in the hot south.
You can get the boss for the probe on the Motorhaven site here. It looks like a hunk of money/work to have one put on. I don't think I would try it myself.
#35
ATTN, KEN
I was reading your post on the new preditor tuner and my only question is how do i know what flash is in my truck know ? i just purchased it jan. 1 and installed cat back banks exhaust and airaid intake system , i am getting gauges installed wed. at a shop in coral springs, but want to purchase this system , but can not be sure what flash my truck has ?
#36
I understand you can go back to stock settings, but does it leave a footprint in the system showing it has been modified? From what I have heard the Bully Dog plugs in , can be remove and the puter never shows a modification was made. Help I would love to chip this puppy but don't want to void the warranty!
BomB Squad
BomB Squad
#37
on
Re: ATTN, KEN
#38
on
BomB Squad
BomB Squad
#40
#43
I got my tuner last night. I was reading the manual and noticed that there is some information that conflicts with info found on this page. On EGT gages it states "Depending on probe location, there will be different samplas - pre turbo(not on exhaust manifold) expect 1300 - 1500 degrees, on down pipe, 1100 - 1200 degrees." Also, it says nothing about "latest factory tune". I assume that since my truck is running O.K. and I want to preserve this tune, I will have the tuner "learn" my existing tune and save it for the future. It looks like the logical way to do the EGT gage is to install the bung in the new down pipe since there seems to be no ready made location.
#44
The Predator works. It saved my flash (I have it now, even if the Ford dealer flashes my truck with a flash that is worse.
I installed the 65 HP performance/mileage flash. It really made a huge difference. The engine really wants to rev up quick. The difference feels like a Stock Mustang getting a 100 HP shot of NOS or a S-Trim Vortech. It must make an extra 150 ft.lb. of torque. The manual says that the computer needs 5 cold starts to adapt the transmission. It shifts very soft now.
I'll write again when I try the 100 HP setting.
#45
