Sponsored by: Auxito
im cold
Old Jan 13, 2004 | 10:04 AM
HAYABUSA's Avatar
HAYABUSA
Thumbs down im cold
i have a 97 f-150 and about two weeks ago my heater started to blow not so hot air and now it only blows c-c-c-cold what does this problem sound like to you guys and how much will it cost to fix
Old Jan 13, 2004 | 02:22 PM
Racerguy's Avatar
Racerguy
Hi HAYABUSA and welcome aboard
What size engine do you have?
Is the coolant full?
Old Jan 13, 2004 | 03:21 PM
HAYABUSA's Avatar
HAYABUSA
it's a 4.2L i think? i have not checked my coolant level. if its low that could be the cause of my heater not working?
Old Jan 13, 2004 | 03:27 PM
MrBSS's Avatar
MrBSS
Yes!
Old Jan 13, 2004 | 03:51 PM
96skeeter's Avatar
96skeeter
sounds to me like you ran out of coolint.....
no water no heat...
i think thats how it works...
Old Jan 13, 2004 | 05:07 PM
PaulC's Avatar
PaulC
No engine either.
Old Jan 13, 2004 | 05:32 PM
HAYABUSA's Avatar
HAYABUSA
yes it was the coolant. I should be banned from this forum and all other forums for the crime of posting stupidness. But thanks
Old Jan 13, 2004 | 05:59 PM
leroys4wd's Avatar
leroys4wd
the better question now is where did it go?
Old Jan 13, 2004 | 07:08 PM
HAYABUSA's Avatar
HAYABUSA
hmmmmm..... I dont know
Old Jan 13, 2004 | 08:46 PM
HAYABUSA's Avatar
HAYABUSA
you guys dont think that hurt my truck do you?
it runs perfect and only has 43000 miles. good for a 97 huh?
Old Jan 13, 2004 | 10:51 PM
LxMan1's Avatar
LxMan1
UhhOhh, sounds like a timing cover leaking to me.
Check the oil for any moisture in it. It will be milky looking. Check out www.leakingfords.com .
Jimmy
Old Jan 13, 2004 | 11:54 PM
z 97ford1's Avatar
z 97ford1
I don't care if it's cold or not.....I'm in arizona where it's been 80 degree's. Going fishing tomorrow. TEE HEE HEE
Old Jan 14, 2004 | 07:35 AM
xxdemon's Avatar
xxdemon
Better check that leak pronto. Mine lost antifreeze into the lower intake manifold and caused a severe knock. Must have got a piston.
Old Jan 14, 2004 | 01:39 PM
HAYABUSA's Avatar
HAYABUSA
how do i check the oil? do i have to drain it?
Old Jan 14, 2004 | 01:45 PM
xxdemon's Avatar
xxdemon
If you pull the dipstick and it is milky looking, you have water in your oil. If the truck has been sitting for a while, loosen the drain bolt until a trickle comes out. Water is heavier than motor oil and the water will be the first to drip out.
