Rear Diff Leak
Old Jan 13, 2004 | 12:18 AM
pglynn's Avatar
pglynn
Rear Diff Leak
I have a 2000 Expedition 4X4 with 48,000 miles. I just noticed a leak on the front of the rear diff just behind where the diff attaches to the driveshaft. Is there a seal right there that has gone bad? Anyone ever have that problem?
I checked the fluid and its a little low.
Any reccomendations?
Old Jan 13, 2004 | 12:25 AM
tsdrallyer's Avatar
tsdrallyer
That's called a pinion seal and yes, it needs to be replaced as there is no fix except removal and replacement. I recommend an experienced drive train mechanic do the job because the tolerances on the pinion are small, and it's easy to do damage.
Old Jan 13, 2004 | 12:30 AM
pglynn's Avatar
pglynn
Do you have any idea what I should pay for that job?
Old Jan 13, 2004 | 01:41 PM
tsdrallyer's Avatar
tsdrallyer
No, I don't have any idea. When mine was done it was under warranty because the mechanic goofed in a LSD replacement and did not replace all seals as he should have so it was at his expense.
