Pilot bearing
Old Jan 12, 2004 | 10:27 PM
doitmyself's Avatar
doitmyself
Question Pilot bearing
Hi and thanks for all your help. Any advice on how to remove the pilot bearing from the crankshaft?
Old Jan 12, 2004 | 10:41 PM
Hank85713's Avatar
Hank85713
what year and motor, mine in my 94, 4.0 is pressed into the flywheel.
If it is actually in the end of the crank you can try and peen it up so you can get it with pait of pliers or something. Try not to bang up where it is mounted.
On mine the bearing is the only part replaced and it is about the size of a dime in diameter, and with the flywheel off you can punch it out real easy.
Make sure you put a little grease on the rollers before you install the transmission. Not a whole lot just a little to add to the factory stuff. My last bearing was totally gone and the cause of my shifting problems.
Old Jan 12, 2004 | 10:52 PM
rudiger66ca's Avatar
rudiger66ca
best way is to borrow/rent a puller some auto parts stores have them for customer use. rather than try to hack it out (it can be done) but it takes a lot longer
Old Jan 13, 2004 | 11:29 AM
doitmyself's Avatar
doitmyself
Re: Pilot bearing
This is a 1992 2.3l 4cylinder engine!!!!!
Old Jan 14, 2004 | 12:52 PM
nightme_02's Avatar
nightme_02
I left a $20 deposit at AutoZone and borrowed their Puller, took 2 thumps and the pilot bearing came right out.
94 4Cyl 2.3L
