Wiper Motors
Old Jan 12, 2004 | 10:10 PM
grover's Avatar
grover
Wiper Motors
Hey there!
Have any of y'all done the 6 volt (or vacuum) to 12 volt wiper motor swap? I've noticed that the kits use the '79 and back wiper motor, so I was wondering if the '79 wiper motor will bolt up where the 6 volt used to be? I already know I'll need a different switch.
I'm REALLY tired of my '54 vintage vacuum wipers, and the (used) wiper motor setup I got in Pigeon Forge had a 6 volt motor.
Any ideas?
Old Jan 13, 2004 | 06:52 AM
55Bubba's Avatar
55Bubba
Hey Don,
It's my understanding (haven't sone it myself) that the square Jeep Cherokees will work with just relocating a hole in the mounting bracket. I remember reading it here on the forum. I know this information isn't much but hope it helps.
Bubba
Old Jan 13, 2004 | 08:28 AM
DS02F250's Avatar
DS02F250
There are a handful of places that sell 12-volt wipers mounted to the OE plate. Check here on MotorHaven or Bob's F-100's or John's F-Fun Hundreds or Sacramento Vintage Ford. If your stock washer fluid still works, don't change it. Just take my word on that one
And forget about "intermittent". (ditto). Just get a simple two-stage wiper switch from whomever you get the motor from. Trust me; don't go there....
Old Jan 13, 2004 | 09:31 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Originally posted by 55Bubba
Hey Don,
Bubba
I must have missed the post on using a Cherokee wiper motor. Sounds interesting. Does anyone have the details?
Old Jan 14, 2004 | 06:29 AM
grover's Avatar
grover
Well, I pulled a wiper motor and a 2-speed switch from a '79 yesterday, and it looks like I'll need to fabricate a bracket, not that that will be too difficult.
The hard part is going to be the rotating arm that attaches to the motor. The 6-volt motor I have is a Bosch unit, and the new motor, of course, is a Motorcraft unit, so the arms won't swap. I'm trying to decide at what I shall do next.
By the way, if any of you have an early Mustang or Mercury Comet, the motor I bought yesterday is a drop in. My COmet has single speed wipers, so guess what I'll be doing when I start on THAT project!
Old Jan 14, 2004 | 06:44 AM
GreatNorthWoods
I don't know how well it works, but J.C. Whitney offers an intermittent wiper delay switch for around 20 bucks which supposedly can be used with most any wiper motor...
Old Jan 14, 2004 | 07:15 AM
DS02F250's Avatar
DS02F250
Vern,
I appreciate that, but I already tried a universal intermittent wiper switch with no luck. Oh well, guess I'll shoot for 2 speeds: Lo and Hi and be happy with that.
Thanks anyway!
Old Jan 14, 2004 | 05:22 PM
Cowman's Avatar
Cowman
Grover, I adapted a Jeep Cherokee (Classic, ie early 90's) wiper motor to my stock '53 F100 linkage. It was easy. All I had to do was enlarge the 3 holes in the stock '53 Ford motor mount bracket and the Cherokee motor bolted right up. If you use a Cherokee Steering column which I did, then the delay module is also a simple snap in piece the goes in the stock harness from the column. Cherokee parts are plentiful and cheap. I paid about $25 for the column and the wiper motor at a local self serve yard. Went thru the column, bought a new key lockset, made a custom mount and it all fits great. Grab the harness and connectors while you are in the yard. If you go for the column and delay, grab the small black plastic box (2x3 inch) that is mounted to the column wiring harness when you get the column. You could probably wire the delay module to a dash switch but I would think that would be a bugger to do.
Hope this helps. If you have any question, send me an email.
Old Jan 20, 2004 | 08:15 PM
budsgarage's Avatar
budsgarage
I put a 74 VW wiper motor in my 54 f100. Just had to adapt the shaft arm to fit. I spent about two hours on the whole job.
Old Jan 21, 2004 | 06:34 AM
GreatNorthWoods
Sure wish somebody could document these salvage yard wiper solutions with pictures...
Old Jan 21, 2004 | 09:26 AM
budsgarage's Avatar
budsgarage
Hey Vern
I am a new computer user and don't know how to do the picture thing. But the VW wiper motor is a pretty simple job. The motor is about the same shape and the mounting holes line up with very small enlargement. The only mod. you have to do is cut the shaft arm. The VW has a tapered spline connection. Looking at your gallery all the mods. you have done so far I don't think you would have any trouble at all. Isn't this web site a great place to learn. I have gained so much information its unreal
Old Jan 22, 2004 | 07:51 AM
GreatNorthWoods
Bud,
I know where you're coming from on the picture thing. I barely figured out how to set up a gallery (and have to re-train myself everytime I go back to add to it) and I still haven't determined how to put a picture in a post.
The problem on my old F-3 is that nothing came with as far as wipers. I have two holes in the cowl and that's it. I bought a linkage for a 51-52 from my bud Nathan here on FTE, but I haven't gotten far enough along on the truck yet to determine how the 51-52 linkage is going to fit (I know it's not the same as 48-50 linkage) and I still have to have some kind of motor (preferably 12 Volt electric) to operate it, so I'm looking at all options. Do you have any idea what year range the VW wiper motors are the same, or would I have to have a 74 specifically? Also, what year is your truck? The 51-52 linkage may be quite different from what you have. I know I could buy a wiper kit for a couple of hundred bucks, but where's the fun in that? It's much more fun to adapt salvage yard parts and I'm on a pretty tight budget...
Old Jan 22, 2004 | 09:22 AM
budsgarage's Avatar
budsgarage
Back at ya Vern
I see where you are coming from now, not having anything to work with. My truck is a 54. The distance between the holes in the cowl are 21 3/8 center to center. If that would work for you the best way to go would be to come up with an old original electric setup and then go with the VW motor. The vacuum and the electric assembly are made different. I (THINK) the VW wiper assembly is the same in about all the 70's. The original ford assembly pretty much mounts just by the attachment to the cowl holes. There is one brace that attaches to the cowl vent assembly.
Hope I have been some help Vern. Some of this stuff just takes time dosen't it.
Bud
Old Jan 22, 2004 | 11:24 PM
Cowman's Avatar
Cowman
I'll try to attach a photo or two of the Cherokee wiper motor (that I mounted on my stock linkage) in my gallery. I haven't clue how to get it attached to this post.
Here goes.....
Success!!! It worked. Go to my gallery for the pics.
Old Jan 23, 2004 | 07:45 AM
GreatNorthWoods
Bud and Cowman,
Thanks for the info. From Cowman's pictures, it's apparent that the 53-54 linkage is quite different from my 51-52 linkage. I haven't measured mine yet, but I'm pretty sure it's narrower than 21 3/8 inches center to center. It still might work though, and I'll file this information for when I get back on the wipers. In the meantime, I'll keep my eyes open for either the Cherokee or VW motor on Ebay. The pictures are a great help. Thanks again...
