Changing to Mass Air
Old Jan 12, 2004 | 08:51 PM
with's Avatar
with
I have a 93 F-150 I'm switching to mass air will a 94 computer work (because I thought 94 was the first year for mass air in these trucks). Also didn't 94 start sequential fuel injection in an F-150.
Old Jan 12, 2004 | 11:18 PM
EPNCSU2006's Avatar
EPNCSU2006
Some California trucks had mass air in '94 as well as sequental injection. The speed density trucks remained batch fire. As long as the computer matches the transmission you have, then that should work. Just get the harness from the truck you get the computer for, otherwise you will have to re-wire to get it to work correctly. It should be quite easy with a donor truck to pull parts from, a little harder if you are piecing it together from scratch.
