1978 - 1996 Big Bronco
torque converter & idle?
Old Jan 12, 2004 | 06:40 PM
kameronth's Avatar
kameronth
well i changed my o2 sensor and my truck still surges at idle and dies. Could a bad torque converter affect idle? sometime my trannsmission does not catch off the line and i am pretty sure it is the torque converter because i had another truck do the same thing. but could it affect my idle or even when i come to a quick stop it will usually die.
Old Jan 12, 2004 | 07:26 PM
jdgreen's Avatar
jdgreen
Do you have a check engine light? I'm guessing you don't or you would've said. I personally would look at a lot of other things before the torque converter. It really sounds more like what I went through before I changed all the sensors. If it were me the first thing I would check is the throttle position sensor. If it's going bad the rapid change in throttle (sudden stop or stepping on it) will confuse the computer.
Old Jan 12, 2004 | 10:16 PM
Corey872's Avatar
Corey872
I'd probably put the TC last on my list too. If you have EFI, you should have a computer with codes stored. Start by pulling them. Also may not hurt to take a look at the fuel pressure. My truck developed a pretty good surge when the regulator shot craps. Of course it could be a whole host of other things, too
Old Jan 13, 2004 | 12:49 AM
kameronth's Avatar
kameronth
yea, my check engine light does flash only when you give her gas. about a month ago i put the code scanner to my computer and the only thing that came up was the o2 sensor which i have replaced with also a new fuel filter, air filter and pcv valve. even if the torque converter is not my idleing problem it still needs a replacement because it slips on initial starts here and there.
