Rear diff ratio
Old Jan 12, 2004 | 04:12 PM
MikeRizz's Avatar
MikeRizz
Rear diff ratio
I looked at the tag on the rear diff today and it reads " 4L30...
Is this a 4.30 axle ratio ? I always thought it was 3.73 ( that is what the used car dealer told me ). I am not complaining if I am reading it right.
Old Jan 12, 2004 | 05:47 PM
Monsta's Avatar
Monsta
Sit. Stay.
Yup. 4.30 Limited Slip.
Nice axle.
Old Jan 12, 2004 | 05:54 PM
Industrial_dude's Avatar
Industrial_dude
which one gives you better gas mileage under normal driving? (without towing)
Old Jan 12, 2004 | 09:25 PM
MikeRizz's Avatar
MikeRizz
Q
Nice axle.
Thanks With the 4.30 does that change the tow rating ?
Old Jan 12, 2004 | 10:40 PM
Sportdeck262's Avatar
Sportdeck262
Mike:
The 2000 Ex has a 10k tow rating with either rearend. The limiting factor was the 5.4v8 vs the real 6.8v10 that you have. The differnce is you'll have more acceleration/power to get the towed load moving. You should also be able to tow in overdrive with limited hunting between drive and o/d.
Dan
Old Feb 3, 2004 | 03:17 PM
TX Big Blu's Avatar
TX Big Blu
Is it possible to tell what rear end gears you have by looking at the VIN?
Old Feb 3, 2004 | 08:32 PM
spartan's Avatar
spartan
Pardon me if am wrong, but the determining factor for towing capacity with a V10 powered Excursion is the rear differential and or a 4X2 VS 4X4 designation. I.E. - the 4.3 is rated higher than a 3.73. I cannot remember the exact specs, but the 4X4 with the 4.3 rear end specs out to haul as much as a PSD basically.
The 5.4 engine doesn't even qualify in this category. Sorry.
Old Feb 4, 2004 | 01:55 PM
Monsta's Avatar
Monsta
Sit. Stay.
Originally posted by Sportdeck262
Mike:
posted by spartan but the determining factor for towing capacity with a V10 powered Excursion is the rear differential and or a 4X2 VS 4X4 designation
spartan is correct. The rear diff is the determining factor.
Look at the specs for the 04 models. The only difference now is that FOrd raised the max (when properly equipped) to 11K. NOTHING else was changed, only the tag.
http://www.fordvehicles.com/Suvs/exc...eatures/specs/
Engine - DT / Ratio - GCWR -Tow rating
5.4L (330) SEFI TritonTM V8 (4x2) 3.73 - 13,000 - 6,100
5.4L (330) SEFI TritonTM V8 (4x2) 4.1 - 14,500 - 7,600
5.4L (330) SEFI TritonTM V8 (4x4) 4.1 - 14,500 - 7,200
6.8L (415) TritonTM V10 (4x2) 3.73 - 17,000 - 10,000
6.8L (415) TritonTM V10 (4x2) 4.3 - 20,000 - 11,000
6.8L (415) TritonTM V10 (4x4) 3.73 - 17,000 - 9,600
6.8L (415) TritonTM V10 (4x4) 4.3 - 20,000 - 11,000
6.0L (363) TritonTM V8 Power Stroke Diesel (4x2 and 4x4) 3.73 20,000 11,000
Old Feb 19, 2004 | 10:04 PM
Taterob's Avatar
Taterob
One question you have not gotten answered is can you tell from the VIN what the rear end Ratio is. The VIN number does not, but the axle code is on the left door jamb label that shows the manufacturer date, tire pressure and the VIN bar code. The axle code 31 is a 3.73 non limited slip. A Ford dealer told me any code with a letter in it is a limited slip.
Another guestion is which gives the better fuel mileage. Normally the lower ratio, ie 3.73 will give better mileage unless you are pulling a very heavy load. The higher ratio will provide more tow power, but in the long run will get poorer mileage. As an example I also have an 2000 F-550 power-stroke pick-up for towing a 18,000 pund fifth wheel. It has a 4.88 limited slip rear, and with no load it only gets 12-13 miles per gallon when my previous 1999 F-350 power-stroke with 3.73 rear got almost 20 Miles per gallon with no load. High ratio rear ends do eat the fuel.
Old Feb 20, 2004 | 07:48 AM
TX Big Blu's Avatar
TX Big Blu
thanks Taterob, that's what I was looking for.
Old Jul 7, 2004 | 11:15 PM
vino53's Avatar
vino53
What would it cost to change from a 4.1 to a 3.73 rearend on my 6.0 PSD
2003 Excursion? I don't tow anything, except a 20 foot powerboat, and not for long distances. Am I crazy even thinking of doing this? Mainly for fuel economy; plan on keeping the X to at least 200K miles.
Bill.
Old Jul 7, 2004 | 11:30 PM
johnsdiesel's Avatar
johnsdiesel
Bill.
If you have the PSD you already have the 3.73. You can't get the 4.10 gears with the PSD unless you buy an F350 dually (as of 1999).
Old Jul 8, 2004 | 06:28 AM
vino53's Avatar
vino53
It was an option that came with the vehicle. I know it has the 4.10 rearend.
Bill
Old Jul 8, 2004 | 11:45 PM
johnsdiesel
Bill
What's the axle code say on the sticker inside your door? I'm willing to bet it's a 3.73. Ford stopped offering the 4.10 with the PSD outside of the F350 dually in 1999. The current model year X also does not list 4.10 as an option with the PSD. If you do have 4.10 gears I'd sure like to know how you pulled that off, and I'm sure others would as well.
Old Aug 1, 2004 | 04:42 PM
vino53's Avatar
vino53
You're right; its a 3.73./ HOw's that for everyday driving? Any reason to change it?
Bill.
