Any suggestions?
Old Jan 11, 2004 | 08:33 PM
wickymustang's Avatar
wickymustang
Any suggestions?
I have a black painted delta tool box in my pickup and i got a huge chip in it and the water got under the black paint/powder coat stuff and now there is a huge silver sput, I need to cover the whole lid in something, I was thinking the roll on bedliner stuff, any ideas?
Old Jan 29, 2004 | 10:04 PM
wickymustang
Anybody at all got some ideas here?
Old Jan 29, 2004 | 10:32 PM
Carlene's Avatar
Carlene
Admom
I'd suggest doing something like touching it up with POR or Zero Rust to protect the exposed metal, but I'm re-directing this to the Paint & Bodywork forum for some expert advise.
Aekisu or 4-Stars????
Old Jan 30, 2004 | 02:25 AM
Aekisu's Avatar
Aekisu
<cr>
I wish more people would read this post. I've heard so many times, "Powder coating is chip proof. You can't hurt it." Hog wash I've always said. Any paint will chip under the right conditions.
Silver spot? Is the box aluminum?
The concern I would have is that the box is steel and if that is the case, the moisture has gotten between the paint and metal.
Let us know something about the box (a picture of the damage would be nice) and we should be able to come up with a solution for the problem.
Old Feb 2, 2004 | 08:18 AM
wickymustang
It's all aluminum, and the spot is about the diameter of a tennis ball, the chiping has stopped but it looks like, well we all know what it looks like.
Old Feb 2, 2004 | 02:29 PM
Aekisu's Avatar
Aekisu
<cr>
If you are going to paint it, you need to clean, sand and either apply an etching compound or self-etching primer to the exposed alumunim prior to topcoating. Myself, I would probably do that (although it may not be necessary) even if I was going to use a bedliner spray.
As to what you
GarrettBabb
Jul 9, 2013 03:40 PM
JaySVX
Jan 13, 2012 07:02 PM
Jacob822
Jul 29, 2007 09:17 AM
Derk38
Nov 24, 2003 12:22 AM
JBronco
1978 - 1996 Big Bronco
Aug 24, 2003 11:32 PM
