starter bolts
Old Jan 11, 2004 | 06:16 PM
bpd964's Avatar
bpd964
Unhappy starter bolts
Does anyone know how many bolts there are to remove a starter for the 1998 Expy?
Old Jan 11, 2004 | 09:26 PM
jrahn's Avatar
jrahn
I assume that you are talking about a 5.4?
if so, there are 3 but you can only feel the one located on the flange above the the starter motor.
I used a flex socket, and two extensions with a universal joint between them.
Of course with a lift, this may be an easy task, but I was on my back on the side of the highway.
Old Jan 12, 2004 | 10:00 AM
bpd964's Avatar
bpd964
Thank YOU!
I have the 5.4 and no lift either. I am stuck in a parking lot and of course it snowed today and I will be on my back in that crap. Than you for your help and I am now headed out to begin..
Thank you
Old Jan 12, 2004 | 01:06 PM
bpd964's Avatar
bpd964
Talking Done
To replace the starter in the Expy 5.4 you will need couple of extentions and rachets and a few band-aids to get to the 3 bolts.
Don't forget to check the starter relay also.
Took me 2.5 hours in the cold on the ground in snow with no lift or jacking up the vehicle.
Thank you for the help / info
