U-joint vibration
Old Jan 11, 2004 | 04:15 PM
cruncher's Avatar
cruncher
U-joint vibration
Once again I have hit pay dirt with the information found on this forum. I had a bad vibration in my '91 Explorer and thought it was an out of balance tire. Took it to the tire shop twice before I was convinced it was something else. The vibration was there when applying gas (at a steady speed or accellerating), but went away when I took my foot off the accellerator. This happened at all speeds above around 25mph. Found several postings in this forum describing this exact problem saying that the u-joints were probably bad. Pulled the axel and removed both u-joints. The needle bearings in one of the bearing cups in the rear u-joint had completely turned to powder. Replaced front and rear u-joints (not very hard to do) and the vibration is completely gone. I appreciate all the useful information found here.
