problem that doesn't go away
Old Jan 11, 2004 | 03:40 PM
jhromy's Avatar
jhromy
Every two months or so my 2002 explorer sounds like a old squeaky mattress when going over a speed bump. Ford keeps replacing my front sway bar bushings and once again I went over a speed bump today and the noise is there. I must of had these things replaced no less than 8 times. This is really getting frustrating, its to the point where i want to sell it and never buy another ford. can anybody explain why this keeps happening?
Old Jan 12, 2004 | 10:00 AM
jhromy's Avatar
jhromy
anybody???
Old Jan 12, 2004 | 10:17 AM
99Xplr's Avatar
99Xplr
Now, if the setup is the same as my 99, then you could try replacing the sway bar bushings with urathane bushings. As the rubber ones age, you get the squeeks that are heard. Hope that gives you something to look at. Let us know how you make out.
Old Jan 12, 2004 | 12:55 PM
jhromy's Avatar
jhromy
where could i get them from??? im not good with cars but i could get someone i know to put them on.
Old Jan 12, 2004 | 02:25 PM
99Xplr's Avatar
99Xplr
Not really sure where you can get them from, but all you should need is a wrench and a little time.
Old Mar 23, 2004 | 02:51 PM
jasnjen's Avatar
jasnjen
I have the same problem with my 02 Explorer. I took it in to the dealer and they are replacing the sway bar inlinks?? whatever that is, along with my timing chain tensioner for another problem. Will get it back in a few days
Old Mar 23, 2004 | 11:48 PM
c96drumm's Avatar
c96drumm
I took my bushings off, cleaned them and applied a bit of silicone grease wherever they touch metal. No more squeakin'!
Old Mar 24, 2004 | 05:41 AM
JerNla's Avatar
JerNla
Hey Jhromy & Jasnjen does it kinda sound like a creaky door when you go over a speed bumb??? My 2000 is doing this it sounds like that!
Old Mar 24, 2004 | 05:49 AM
unit5alive's Avatar
unit5alive
jhromy, energy suspension makes greaseable bushings for that problem, have a grease fitting on them, had same problem with a ford van ,havent heard a noise since!
Old Mar 24, 2004 | 06:04 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
You might look at central4wd.com or contact them directly and see what they have to offer.
Old Mar 24, 2004 | 07:40 AM
jhromy's Avatar
jhromy
yeah i had them replaced a while ago with energy bushings and end links...no more problems...
Old Mar 24, 2004 | 07:09 PM
JerNla's Avatar
JerNla
Is the sway bar also know as the stabilizer bar ??
Old Mar 24, 2004 | 07:55 PM
c96drumm's Avatar
c96drumm
Yep. Also anti-sway bar and anti-roll bar, all the same.
Old Mar 24, 2004 | 08:15 PM
JerNla's Avatar
JerNla
Thanks c96drumm, do i just greese it or should i pay 50 to get it "Profesionally" fixed???
Old Mar 24, 2004 | 09:37 PM
c96drumm's Avatar
c96drumm
Personally, I'm inclined to do it myself before I'd pay someone else. Besides, these things are really easy to do. Good luck!
