Sponsored by: Auxito
high pitched whine
Old Jan 10, 2004 | 11:16 PM
melvind's Avatar
melvind
high pitched whine
when the weather turns cold (like it is now..around 10 degrees or worse) My 97 f150 makes a high pitched noise when put in drive and accelerating at the top end of the gears. Usually it goes away after the truck has been driven for a few minutes but lately it lasts alot longer. It does not affect the way the truck drives or performs and none of the guages move a bit. Combine this with the moisture in the oil filler tube, and lunging,hesitating at low rpms in drive and I am starting t get worried. Any ideas?
Thanks,
DM
Old Jan 11, 2004 | 11:44 AM
Racerguy's Avatar
Racerguy
What size engine? Any history of problems before this?
Old Jan 12, 2004 | 08:38 AM
melvind's Avatar
melvind
I have the 4.6-V8. The only problems I have had are moisture in the oil filler tube (when the weather is cold) and a frequent "shudder " when moderately accelerating through the gears(which does not happen if I am accelrating aggressively).
Thanks for your help and pardon the spelling.
