Sponsored by: Auxito
pin stripe color code needed
Old Jan 10, 2004 | 08:22 PM
NCF150's Avatar
NCF150
Question pin stripe color code needed
I need the color code that the dealership uses for the red pinstripe found on some blue/gold and black/silver two toned supercab F150's. It is the same color as the "F X" in the "F X 4" Off Road decal on the 2002's and newer.
Old Jan 11, 2004 | 07:46 PM
NCF150's Avatar
NCF150
Correction, the bright red stripe comes on some blue/dark gray or black/dark gray two-toned F150's (usually SuperCab's). Thanks to anyone who can help.
Old Jan 11, 2004 | 11:58 PM
Racerguy's Avatar
Racerguy
The manual that I have doesnt show any stripes with red in them on either a 2001 or 02 truck.
Why do you need the code?
Can someone make up the stripes for you? Where I am we have a Trim-Line outfit that can make up pretty much any sort of stripe or decal you coudl need.
Old Jan 12, 2004 | 05:40 PM
NCF150's Avatar
NCF150
I have only seen this color stripe on the 02's and 03's. If you go to the users galleries section of this site and set the filtering to 2002 - F150 - 4X4, then click on the user N2BNHI (should be 7th from the top) for an example. I have never seen this up close in person so im not sure if it is a single red stripe or a two toned stripe like most F150s have where the other color matches the body color of the truck. The reason why i want the color code is because that color red matches the "F X" in the "F X 4" stock decal exactly which is the look i am going for. How close can the "Trim-line" outfit match colors? The guy at the parts dept. at the Ford dealership said i would need either the color code or the Vin # of a truck that came with this color stripe in order to make a match. Any more help or advice would be much appreciated.
Old Jan 12, 2004 | 07:26 PM
Racerguy's Avatar
Racerguy
The Trim-Line place here has tons of different shades of most colors and can match nearly anything. He does work for a lot of bodyshops, replacing stock stripes etc. Maybe see if anyone in your area does that too.
In 2003 they show tape/stripe code R — Dark Shadow Gray/Bright Red
I wonder if that's the same?
I see you left a message for N2BNHI in his gallery. It doesnt look like he comes here any more but you might still try emailling him.
If you find his name in the member list you can email him through there.
Old Jan 12, 2004 | 07:40 PM
NCF150's Avatar
NCF150
That code, "R", must be it because i have only seen the red pinstripe on F150's with dark gray trim. Do you know if when you order the stripe from the dealership, does it come pre-cut to match your body style (reg,ext,crew cab)? If so, can you get the "R" stripe for a SuperCrew? I am thinking the picture i directed you to before was a custom job because i have only seen this stripe scheme on SuperCab's. Thanks for the code information.
Old Jan 14, 2004 | 07:04 PM
Racerguy's Avatar
Racerguy
I got our partsman to look it up today and in 2003 anyway the tape code R was available for a SuperCrew. The stripe kits are specific to regular cab, super cab and SC trucks so it should fit like it was made for it.....it was
gdzero
Apr 10, 2026 08:03 AM
1986F150six
16
Jun 9, 2015 10:03 PM
Yahiko
Mar 12, 2015 12:36 AM
CoachJoe
2009 - 2014 F150
Jan 8, 2013 05:11 AM
ironmine
Dec 7, 2005 12:58 AM
