Sponsored by: Real Truck
Radiator Question
Old Aug 20, 2002 | 06:18 PM
Quikirk's Avatar
Quikirk
Radiator Question
Ok people, here's my dumb question for today. It has to do with draining the radiator. You'll get a chuckle out of this but that's ok, maybe ya can give me a little advice from all your experience. I was looking at the radiator drain valve in anticipation of installing a power fan. Ya have to drain the rad to be able to remove the upper rad hose. Looking at the valve, it has the little black drain tube with the nut on the back whicj you'd loosen to drain the rad, and there's a small pipe barb, nipple, whatever on the pipe which I thought ya could install a piece of tubing to for draining. I thought, cool, this will make for a neat drain, just hook up a piece of tubing to the nipple, put the tubing in a gallon jug and open the valve. I could drain out a gallon at a time or whatever I needed. WRONG. I thought I'd give it a try and attempted to drain some into a gallon jug. Oh well, when you open the valve far enough to get coolant out of the hose barb it leaks like hell out of the back of the pipe where the nut is located that ya loosen. Sooooo, I guess ya gotta use a LARGE pan, bucket, or who knows what to catch all the coolant that's gonna gush all over the place. Then what's the easy way to get this giant bucket or whatever full of coolant Back into the radiator? Anybody got any good tips? Thx.
Old Aug 20, 2002 | 08:53 PM
Monsta's Avatar
Monsta
Sit. Stay.
Radiator Question
Tip #1. Have someone else do it.
Tip #2. Remove the tube and see if it flows correctly and not out of the wrong places.
Yours, if like mine, points straight down. Why put a hose on there at all?? Just drain it straight into a large basin.
Refill the radiator with a BA funnel. A screen placed (taped) on the top may help remove any foreign debris and helps to reduce splashing.
Are you installing a Cyclone? Or an electric fan?
Old Aug 20, 2002 | 10:04 PM
Quikirk's Avatar
Quikirk
Radiator Question
Monsta, thanks for the tips. You got a good point about taking the piece of tubing off of the nipple. I thought this might be neater (since I'm a neat freak), but it doesn't work. I'll try your recommendation. I'm hoping to install a Cyclone Power Fan (clutch) soon. I will let everyone know the outcome. Thx
Old Aug 26, 2002 | 09:19 AM
warmdye's Avatar
warmdye
Radiator Question
Anybody tried an electric fan yet?
Old Aug 27, 2002 | 07:24 PM
Gary E K's Avatar
Gary E K
Radiator Question
I have heard of an electric fan, but I never heard of a Cylone fan, only in a "Vacuum cleaner". Tell me what it is. "I" might want one too.
Old Aug 27, 2002 | 08:02 PM
Yeti's Avatar
Yeti
Radiator Question
