E40D Blues
Old Jan 10, 2004 | 07:36 PM
Fully_Loaded's Avatar
Fully_Loaded
Unhappy E40D Blues
I have searched the forum and have not found a whole lot of things pertaining to my tranny probs. My 91 ford (see sig.) has got some tranny probs. It has about 60,000 SMOH. This is what it is doing. Shifting to reverse no prob. Shifting to drive there is a hesitation and this is where the prob. starts. I take off down the road under normal accel. and it shifts 1 to 2 fine most of the time. When it is time to go to 3 it winds up real high then slams into 3 then shifts to 4 somewhat normal. While in 4 it will slip in and out of gear. About a 200rpm difference during the slip. When you go from a dead stop and accelerate hard it seems to shift ok 9 out of 10 times. I changed fluid and filter to no result. It also hunts for gears at very slow speeds, 5-20mph. Please help. I am trying to avoid a $1500 rebuild, I also believe that I am beating a dead horse. Could it be soleinoid packs?
Old Jan 10, 2004 | 09:55 PM
bigbadjs's Avatar
bigbadjs
Troublecodes?
Old Jan 11, 2004 | 03:25 AM
willd's Avatar
willd
T/C going south, solenoid plugged? PCM lost, or has bad program.
Get a tech manual and some pressure guages.
Read the codes if it has some.
Go talk to a mechanic that works for a place that has a fleet of ford work trucks. They rebuild e4od's for a living.....
Old Jan 11, 2004 | 10:25 PM
Fully_Loaded
I cannot get any service codes out of it. I have a code scanner and I tried the flash of check engine light nothing.
Old Jan 20, 2004 | 07:20 PM
924x2150's Avatar
924x2150
Re: getting codes: are you saying, that you don't know how to get the codes...the truck won't activate self test...or there just aren't any codes?????
Old Jan 21, 2004 | 09:30 AM
willd's Avatar
willd
Mine did very similar things. It was one of the solenoids and the t/c.
The hard shift is the tranny building up too much pressure. The hunting is because the t/c clutch isn't locking right and causes the tranny to hunt.
Just my guesses without tearing into it.
Old Jan 21, 2004 | 02:43 PM
jimandmandy's Avatar
jimandmandy
Re: E40D Blues
OFF TOPIC:
Do you own an airplane?
Jim
